body ground
M-man's Avatar
06-04-02, 11:10 AM   #1
M-man
body ground
where is the body ground on my '93 astro? my problem is very
similar to ''rguide.'' when i turn the key, nothing happens. no
radio, gauges, door locks, wipers, etc. all i do have is lights and
horn. like '' rguide,'' i had the battery checked: OK. HELP!!
trinitro's Avatar
06-04-02, 11:13 AM   #2
This sounds more like a bad ignition switch or a bad main relay then a bad ground...
M-man's Avatar
06-04-02, 12:02 PM   #3
M-man
Thank you, Trinitro, for the quick response! What and where is the main relay?
davo's Avatar
06-04-02, 01:58 PM   #4
Check the fusible links at the starter for being melted or corroded.This would cause this problem also.
trinitro's Avatar
06-04-02, 02:49 PM   #5
If this only occurs sometimes then it shouldn't be a fusibile link. Most likely it will be a bad switch. I'm not sure where the main relay is in the car, but probably a Chilton's book or an Alldata subscription will locate it for you very quickly.
