toyota 4x4 1992
mark caniparoli's Avatar
06-08-02, 08:22 AM   #1
mark caniparoli
toyota 4x4 1992
My son's 1992 toyota 4x4 w/ v6 and manual transmission will not engage into 4 wheel drive. The light on the dash started blinking one day, then quit flahing all together and since then he has been unable to get the truck to lock into 4 wheel drive. The truck doesn't have locking hubs, so I ruled that out. Any suggestions??
I don't think that it is an electrcal problem. When you shift the transfer case into 4wd, the front drive line has power to it, but the axels don't. Could it be a vacum problem. There appears to be a vacum modulator with two vacum lines going to it taht is bolted to the front end housing.
Joe_F's Avatar
06-08-02, 03:35 PM   #2
Joe_F
If it's electrically operated, you might look for a stuck solenoid. This is a common problem on Fords where the brushes get glazed...it's especially problematic when the 4WD isn't used much.
davo's Avatar
06-09-02, 05:52 AM   #3
Check for vacuum at the front axle actuator,if you have it the actuator is most likely bad ,if you dont start tracing back the vacuum line till you find a leak or a bad vacuum switch.
