Changing mazda 626 spark plugs problem
matto_007's Avatar
06-08-02, 01:02 PM   #1
matto_007
I own a 1995 mazda 626 but there is a problem with changing the spark plugs. At the end of the spark plug wires there is a long plastic piece and at the end of that there is the spark plug boot. The problem is when I take out the spark plug wires off of the spark plug the rubber boot stays attached to the spark plug and I have no idea how to get it off. If anyone can help it would be greatly appreciated.
Joe_F's Avatar
06-08-02, 03:27 PM   #2
Joe_F
If the boots separate like that, the wires are likely wiped and should be changed for a new set.
You can twist off the rubber with a pair of pliers or cut it with a razor since you're likely going to have to change the wires anyhow.
