Firing Order for a 1977 Olds 98 8 Cylinder 403k 6.6l,4Bl
Old 06-08-02, 09:52 PM
lorraine03
Need to know what the firing order is on the 77 Olds 98 and where does number 1 start on the distributor cap.
Old 06-09-02, 12:24 AM
knuckles
Arrow
1-8-4-3-6-5-7-2. Distributor rotates COUNTER clockwise. See the diagram below.
Image copyright 2002 Alldata LLC. Used with permission.
Old 06-09-02, 09:14 AM
lorraine03
77 olds 98 firing order
knuckles thanks so much for the diagram it was just what I needed. Now can you tell me what else to look for to make the car stop stuttering when I take off. Thanks Lorraine03
Old 06-09-02, 09:17 AM
Joe_F
Full tune up with all plugs and filters without question.
Could be carburetor issues on something this old. Choke problems, generally worn out carburetor. Probably time for a rebuild at this age.
Old 06-09-02, 09:20 AM
lorraine03
77 olds stutters
Thanks Joe, I will check the carbeurator and then tell her to take it to a shop for a tune up. Just a friend trying to help another. Thanks for your help
