10 min. flushes
Old 06-13-02, 08:48 AM
E
10 min. flushes
Does it make any sense to use the 10 min. flush products for an aluminum/plastic radiator?
Is
Old 06-13-02, 08:56 AM
Joe_F
No. If it's that clogged pitch the radiator if professional flushing at a radiator shop doesn't help.
If you're the same guy
Old 06-13-02, 11:03 AM
thiggy's Avatar
Along the same lines, should you use a commercial radiator flush when you replace the coolant (routine maintenance).
Old 06-13-02, 01:34 PM
Joe_F
If you flush your cooling system yearly as you should, you can leave those flushes on the shelf. No need for them.
I never use them. I'm just regular on the maintenance. That is the key .
