Fuel filter problem
Old 06-15-02, 11:17 AM
Opedope
Fuel filter problem
How do I change the fuel filter on a 1995 buick lesabre?
Old 06-15-02, 12:06 PM
Joe_F
See if the repair procedure is located at www.autolibrary.org
If not, time for a shop manual from the parts store.
In short, depressurize the system, find the filter by following the lines out of the tank, cover the old filter with a rag to catch the fuel (no sparks, don't smoke, watch your trouble lamps!), use two wrenches and loosen the filter, drop it out and reverse to install it. Check for leaks and you're done.
