stripped allen head bolt
Old 06-15-02, 06:49 PM
doug hines
stripped allen of bolt. can't put bigger size allen head in,tryed sawing a slot, it didn't work! help, need to get water pump off!
Old 06-15-02, 08:09 PM
Joe_F
Get a vice grip on there and try to loosen it if you can.
If not Sears or any hardware store sells extractors and bolt removers which usually work with any drill.
Old 06-16-02, 02:09 AM
knuckles
By chance are you working on a VW?
Old 06-16-02, 09:47 AM
daffy13
Cool
Try cutting into the bolt with a cold chisel.This will make a groove to get a grip on by tapping the bolt to the left.work your way around tapping left until loose enoughthe grooves only need to be shallow,and of course dont miss the cold chisel and belt the timing cover.fixed the same problem last week this way.
Old 06-17-02, 09:04 AM
quincyguy
loosen
squirt a bit of Kroil on it and tap away.
That stuff is the bee's knees!
