Honda Accord SE - Idiot/Dummy Lights on
Old 06-16-02, 08:37 PM
pkrug
Question Honda Accord SE - Idiot/Dummy Lights on
I have a Honda which all of the dummy/idiot lights (doors, brake, trunk) will turn on and off. I have noticed at times that when I press on the gas the intensity of the lights increase... The check engine light is on but this I believe is the oxygen sensor needs replaced which I will be doing soon.
Any Ideas?
Year : 1991
Make : Honda
Model : Accord SE
Trans type : Automatic
Thanks
Old 06-17-02, 02:07 AM
Joe_F
A bad alternator or an errant ground will also cause this. When the alternator discharges or intermittently charges, it will cause screwy things like this to happen.
Verify the alternator output is good. See my post "the Basics" below.
That being said, also pull your codes using the link to www.batauto.com as a guide.
