"ERROR" on the odomoter
Old 06-20-02, 09:29 AM
Deltadudey2k
Question "ERROR" on the odomoter
I changed out the headlight/dash switch. When I turned it on the ERROR came up on the odomoter. (1993 Aerostar) Can I fix it or do I have to take it to Ford Service? Thanks for any advice
Old 06-20-02, 09:45 AM
Joe_F
Check with www.autolibrary.org to see if they have anything on that.
Never heard of that when changing the dash switch.
Old 06-20-02, 04:15 PM
chadtoolio
Is the odometer reading in that van a digital one? If so the mileage could be redundantly stored in the headlight switch control unit and changing it could have triggered an odometer tampering warning....
Old 06-21-02, 01:03 AM
knuckles
The odometer is digital, but Ford stores the mileage in a chip within the instrument cluster assy.
Check your inst. panel connections & grounds. If they're all good, do as the service manual says & replace the inst. cluster. Your local Ford dealer can have your existing unit rebuilt or exchange it for a reman unit if you supply accurate mileage & proof of ownership.
