front tire squeal
Old 06-24-02, 06:49 AM
wacres
Question front tire squeal
Hi - I have a 1998 Chevy Venture. I have just started to hear a squeal on the right front tire. When I am driving and I turn to the left the squeal goes away. When I am driving straight or when I turn to the right the squeal is there.
The noise is there only once every tire revolution. When I drive slow the squeal is intermittent and only there once per tire revolution. As I drive faster the noise increases as the tires are rotating faster. There doesn't seem to be any increase or decrease in the noise when I apply the brakes.
Thanks for any help.
Old 06-24-02, 08:38 AM
daffy13
hello,could your wheel bearing be the cause?the side closest to the kerb normally gets most wear as it rides most often on rough road edges etc.
Old 06-25-02, 09:11 AM
Joe_F
Take off the tires and look for any signs of rubbing on the brake hoses or other suspension members first.
My Saturn had a similar problem...the issue was a misrouted brake hose. Since been corrected, no problems.
