OK
OK
06-26-02, 04:57 PM
Joe_F
I suggest you get an OEM service manual or at minimum a Chilton or Haynes. Be forewarned that the two latter ones are very generic.
06-27-02, 06:27 AM
That is the purpose of this board, although you don't deserve a reply I will give you one anyway. Here we try to help you, but you've got to help yourself. You have heard the one about give a man a fish and you feed him for today. TEACH a man to fish and he can feed himeself for a lifetime. Get a manual, not only will you use it now you'll use it over and over.
06-27-02, 09:08 AM
Joe_F
If you want short instructions they are the same for any vehicle...basically off with the old, on with the new. Use one side as a guide to do the other. That's the best advice anyone can give you.
We can't possibly cover all the things you could encounter here. That's why you need a book to guide you as well. Easywind gave a better analogy that I could drum up, so Kudos.
I own a manual for EVERY car I own, from my work car on up to my classic Trans Ams. They've paid for themselves already 3 times over.
If you think of the cost of a manual in the terms you're thinking of, you need some reality checks
. An OEM manual set will run you 120 bucks, I'll bet a proper brake job will run you a lot more
I'll also assume you didn't try the library for a free copy? Again, barring that, time to up the ante and buy the book. It's worth its weight in gold.
