engine not running
Old 06-30-02, 09:19 PM
bmbest
Angry engine not running
On my 97 Ford probe, It jumped timimg so I reset the timing and double checked the distributor for position on #1 cylinder. Everything looked fine. but when trying to turn engine over it will turn over but it sounds like a whirling noise. I am really dumb-founded on what to do next. I am getting fuel to the injectors and good fire on the spark plugs. I am in desperate need of some assistance
Old 06-30-02, 09:58 PM
if it jumped timing as in the timing belt jumped , you might want to check compression.
Old 06-30-02, 10:23 PM
bmbest
We did check the compression. It is Fine. I'm just wondering if there is anything electrical that I can check to see if that would be the problem.
Old 07-01-02, 05:44 AM
Joe_F
Sure it's not an interference engine (check the Gates rubber website). If so, bent valves are a possibility.
Sure the timing's right?
Trackbacks are On
Pingbacks are On
Refbacks are On
