97 Ford F- 150 4WD
Old 07-01-02, 07:10 AM
wingplow
97 Ford F- 150 4WD
Can anyone tell me how to remove the front rotors. I pulled the caliper and the caliper mount. I also pulled the axle nut but it will not move. It just does not want to move. Any help will be greatly appreciated.
Thanks
Old 07-01-02, 08:12 AM
JackMaster
Rotor removal
Wingplow,
I have an idea there is another spindle nut. Take a rag and a screw driver, poke the rag in between the spindle and the rotor and use the screw driver to spin the rag around the spindle to clean out all of the grease. Then look inside the opening with a flashlight. You should find a retaining clip or half-ring that has to be removed and then a second nut and large washer that has to be removed. The rotor should come right off then. Let me know your progress.
Mike
Old 07-01-02, 09:26 AM
Joe_F
Check the autolibrary.org link in my signature file.
I just quickly checked...they have the R&R procedure for the rotors and everything else in there.
