replacing u-joint on 4WD '95 cherokee
Old 07-01-02, 08:35 AM
bledsoe
It's the front left wheel u-joint that I'll be replacing. I'm planning on removing the tire, caliper, rotor, outer bearing, inner bearing(?), then unbolting the hub from the steering knuckle and being able to pull the the axle shaft right out so I can throw it into a vise and get replace the u-joint. Can somebody that's done this before tell me if I'm close? Will the axleshaft really just slide out of the differential once I free up the hub? I've never even touched a bearing before, so i'm not too sure what too expect here. Also, when reassembling, do I need to re-grease the bearing?
Thanks
Old 07-01-02, 08:47 AM
Joe_F
Sounds like you're on track. Which bearing are you talking about regreasing? If you mean the hub bearing, those are usually sealed.
Old 07-01-02, 08:53 AM
bledsoe
Yeah, I was talking about the wheel bearing. I'm not sure what to expect there. I've seen exploded diagrams before, but that's it. OK thanks. I just wasn't sure if the axle shaft would really just slide out after I free up the wheel.... I figure it was at least held in the diff by a clip or something
thanks
