1992 Acura Integra Radio/Electrical System
MGM's Avatar
07-02-02, 03:58 PM   #1
MGM
Do-It-Yourselfer’s—
I have a 1992 Acura Integra four door sedan. The problems I am experiencing are related to the radio and/or electrical system.
The car has the factory-installed AM/FM stereo w/cassette player. Yesterday, after the car was parked in my garage all weekend, I had a problem when I started the car. When I turned the key in the ignition, I heard a clicking sound. I looked up to notice the LED clock on the dash was reset to 1:00, all the AM and FM presets were gone, the “door open” warning light was lit, and the motorized antenna did not extend.
I turned off the car and tried again. Same thing. The car starts and all other systems work without a problem. I noticed that if I have the radio on, I cannot read the clock and the “door open” warning light remains lit. If I turn the radio off, I can the clock is lit and the “door open” warning light turns off. If I set the clock, or preset a radio station, then turn off the car, when I start the car, the clock reverts to 1:00 and the presets are gone.
Several years ago, the antenna motor was replaced. However, then the only problem was the antenna not extending. I never had problems with the clock, radio presets, or warning lights.
Any idea on what is causing this problem? What could have happened? Everything worked fine on Friday evening when I parked the car, but this all started Monday morning. Is high heat to blame? The garage reached about 100 degrees F over the weekend, but that shouldn’t be any hotter than sitting on a parking lot all day in direct sunlight and 95 degree F heat.
Thanks in advance for your help.
MGM
Joe_F's Avatar
07-02-02, 04:03 PM   #2
Joe_F
Sounds like a loose battery cable, poor connection or a wiped out battery/alternator.
Have the battery and alternator load tested by a parts store. My post "The Basics" below has an alternator load test you can try.
