Replace engine in 1988 Pontiac Gran Am
Old 07-03-02, 03:31 PM
GaryN
Question Replace engine in 1988 Pontiac Gran Am
I have a 1988 Pontiac Gran Am with a 2.5L engine/Automatic transmission/A/C. I also have 1988 Olds with the same engine. I need info on changing the engines.
thx
GaryN
Old 07-03-02, 04:27 PM
Jason R's Avatar
a 1988 olds what?
Do the mounts look the same? It probably will work, but how much modification is hard to tell from here.
Old 07-03-02, 04:36 PM
Joe_F
I agree. It had better be the same vin U 2.5 as in this 88 Grand Am, or it's not going to work. Check the 8th digits of the Vin on both cars to make sure they are the same thing. Then it should work.
Check the autolibrary link below or a service manual for R&R steps.
Old 07-04-02, 07:45 AM
GaryN
Lightbulb
thank you for good tips
Old 07-06-02, 10:09 AM
waterhead
GOOD LUCK.I JUST PUT A 2.5 IN A GRAND AM.just alond you a some common sense about cars it is pretty easy. hahaha
