94 Mazda 626 stalls
Old 07-05-02, 09:21 PM
dolbydigital
Question 94 Mazda 626 stalls
My 94 Mazda 626 108k mile 2.5L V6 5-speed stalls with no warning. Going down the road and tach goes to zero even though it is still in gear. Seems heat related. If you let it sit for a moment it will start back up but will stall soon after. Longer it sits the longer it will run. Any answers?
Old 07-06-02, 09:59 AM
waterhead
626
My guess check the distributor.thats how my dads 626 did .He had to replace the it.Theres also a hose in the breather hose check it to .that would be my guess.GOOD LUCK
Old 07-06-02, 01:40 PM
Joe_F
Could be anything. Typically a module/igniter that has heat soak problems will do something like that.
Next time it happens, pull over, pull off a spark plug wire, ground it to metal and crank it to see if you have spark. If not, it's ignition related.
Trackbacks are On
Pingbacks are On
Refbacks are On
