Grand Voyager will not start
Old 07-06-02, 09:42 PM
sfslenes
Question Grand Voyager will not start
I have a 1991 Plymouth Grand Voyager 3.3L V6. I am having problems with it not starting. I have followed the manual to troubleshoot the problem.
1. I have checked the spark at the ignition module and the plug end. Both Ok.
2. I have checked the fuel injection lines pressure. There is pressure.
3. I have checked the fuel lines. OK.
4. The battery is okay.
5. I thought it had a broken timing chain based on what the manual told me. However, after draining everything (oil, and coolant) and removing the oil pan, I found that the chain is still on and appears okay.
I recently bought this from someone else. It had a new ignition put in. It had a tune up. And various other work done unrelated to my main problem.
I am not sure where to go with this problem next? Any ideas?
Old 07-07-02, 03:26 AM
Joe_F
----Must be fat, blue and consistent or we're dead in the water.
----Must be checked with a reliable hand held pressure gauge. Volume and pressure are important. Without this it will never run.
---Only tells us there is fuel getting up top. See #2 above.
---Assuming it can turn the starter rapidly enough, Ok.
---Still may have jumped time and it will not start if it does. If it has a distributor, remove the cap and make sure the rotor turns when you crank it. If not, the chain has jumped time or has fallen off/slackened.
How many miles on it?
