73 plymouth duster
roselipsxox's Avatar
07-07-02, 04:46 PM   #1
roselipsxox
73 plymouth duster
please help me..we are having trouble changing the brake shoes..can you tell me anywhere i can look on here that can tell us how to do it ourselves?thank you so much.
joanne
Joe_F's Avatar
07-08-02, 03:40 AM   #2
Joe_F
You can use the other side as a guide for the side you are doing . That's the best way.
If not, I suggest you to go your local library or parts store and pick up a repair manual such as a Chilton or a Haynes. The old ones are pretty detailed and will give you a lot of help.
I always hated those Chryslers with 4 wheel drum brakes. It's like stopping a bus! My sister had a 1974 Gold Duster (with the optional snake skin vinyl top). It was one hardy little car and never failed her once in the couple years she had it. Factory ice box air too
07-08-02, 08:41 AM   #3
roselipsxox
my duster
thanks Joe,we did that and then found out the brake line is broken.i was wondering why i didn't hear any scraping..but the brake fluid was going down.now we have to get the brake line fixed.arggggggggggggggggggggggggggg
thanks again,
joanne
Joe_F's Avatar
07-08-02, 08:55 AM   #4
Joe_F
You might call up Fine Lines, Inline Tube or Classic Tube. They make prebent brake lines for most applications. If not, they can make you an exact copy from your old one...even if it's broken.
07-08-02, 09:12 AM   #5
roselipsxox
brake line
thanks..will do.
joanne
