1992 Plym Gr Voyager fuel filter replace
Old 07-09-02, 10:31 AM
D
Donophyn
Hi,
Is there any special precautions for replacing the fuel filter in 1992 Ply Gr Voyager, 3.3 FI engine, that I should know about? Note with filter says the system is presurized.
Thanks
-----Donophyn
Old 07-09-02, 12:10 PM
Joe_F
Check the autolibrary. org link below.
You should relieve the fuel system pressure. Pull out the fuel pump relay and crank it till it runs out of fuel. Should be ok.
In lieu of that, wrap the filter in a rag and shield your eyes. No smoking!
Old 07-14-02, 06:30 AM
D
Donophyn
Smile Thank you
Thank you, Joe, for your advice. I didn't end up pumping the gas out, I just opened the gas cap and replaced it. There wasn't very much gas that came out, just what was in the filter and I kept it horizontal and there was very little then. The hardest part was just getting under the van. LOL
Thanks again.
