98 Jeep Cherokee rear door handle
Old 07-09-02, 12:29 PM
Jim45
The rear door handle on my 98 Jeep Cherokee is loose. It moves about 1/8 inch on the right side where the lock is. I took the inside door panel off to view the handle from the inside and I see the nut on the opposite side of the lock but there doesn't seem to be one on the side that is loose. This should be a simple tighten job, but what do I tighten?
Thanks,
Jim
Old 07-09-02, 06:25 PM
Joe_F
Hit your Chrysler dealer's parts dept for a printout/exploded view of the door so you know what you're up against. Barring not being able to tighten it, the handle itself may be fatigued and require replacement.
