Abs ?
Old 07-09-02, 06:25 PM
T
Abs ?
I had the left front rotor replaced on my 95 ford ranger after 2 of the studs for the lugnuts broke off. Both sides had the brake pads replaced about a year ago. After doing this the antilock brakes " kick in " almost everytime I apply the brakes while turning. Is this because the left side is stopping better than the right side? Will changing the right side caliper help? Thanks Tim
Old 07-09-02, 06:27 PM
Joe_F
Did you replace both front brake rubber flexible hoses? They are the likely cause of clogging and brake hang up.
Replace them both, flush out the system bleeding it correctly and see if that improves things.
Old 07-09-02, 06:32 PM
Is that the correct rotor for ABS? It may be missing the notches for the sensor to read.
Larry
Old 07-10-02, 03:54 AM
T
Thanks Joe_F I'll give it a try.
Toyotaman11769 I think its the right rotor. I does have the slotted abs ....thingie.
I just thought this starting right after replacing (1) rotor was kinda funny. I thought maybe there was too much grip on the left side brake causing it to trigger the antilock
Old 07-10-02, 05:16 AM
Does it pull ?
Larry
Old 07-10-02, 01:29 PM
T
No Toyotaman11769 it doesn't. I noticed today that it sometimes it does the antilock thing without even applying the brakes. Or at least it sounds like it is.
Old 07-10-02, 01:53 PM
If it worked fine before you changed the rotor, I would have to go back to that point and see what changed.
Wrong rotor, sensor damaged, metal filings stuck on sensor etc
Larry
Old 07-10-02, 02:09 PM
T
Good point Toyotaman11769. I had it done by Midas. Normally I would have done it myself but I got lazy. That'll teach me.
