transmission
Old 07-11-02, 10:52 AM
D
davidwayne
Unhappy transmission
We have a 93 jeep grand cher. with overdrive.. It drives fine except when you pull out. When you are driving it doesn't want to change from 1st to 2nd, it goes back and forth, unless you either let off the gas or give it more. the fluid and filter are fine and i also checked to see if all the hoses where ok ..any help
Old 07-11-02, 04:32 PM
Joe_F
Have the linkage checked by a reputable transmission shop.
However, this has been one collosal bomb of a vehicle from Chrysler .
There are a plethora of service bulletins and woes that match your description/problem....could be a sign of internal failure:
Here are the bulletins. I assumed it to be a 5.2 V8:
http://www.alldata.com/TSB/04/930418DA.html
Note many A/T bulletins and "delayed upshift" and no shift concerns.
