R12 or R???
Old 07-12-02, 08:37 AM
mako's Avatar
R12 or R???
I had posted on here that I had a big can of R12. Well, I went back to Mom's house and dug the can up. A big green cylinder, 15 lbs, of Dupont Freon 22.
So, does that make this R22? And if so, is this stuff any good for automotive or home? If not, what should I do with it? It's at least half, if not 3/4, full.
Old 07-12-02, 08:48 AM
Joe_F
R22. Cannot be used in your vehicle. It requires R12 or a conversion to R134A.
Old 07-12-02, 09:24 AM
T
R22 is used in residential AC units.
Old 07-12-02, 09:58 AM
mako's Avatar
Crud
Maybe I should save it? What should I do with it then? Does the law apply to it the same as R12?
Old 07-12-02, 10:41 AM
T
I'm not sure. If you post this in the heating and cooling forum a professional will be able to help you.
Old 07-12-02, 11:10 AM
mako's Avatar
Good point. I have the automotive part bookmarked so I forget tha this site has everything on it.
Old 07-12-02, 12:45 PM
Joe_F
You need gauges to install it into a home A/C unit. Same rules apply as cars. If you don't have the tools, knowledge and know how, let a pro handle it.
You could save yourself some money if a tech is willing to use it and your central air needs servicing .
Old 07-12-02, 01:46 PM
mako's Avatar
Oddly, I have a set of gauges that Dad left me but I won't use them since I haven't a clue what I'm doing. And since I plan on renting for the next few years (finishing my B.A. Religion) I'll just do what I can to sell it.
I posted on the heating/cooling forum, waiting for some advice there.
Thanks all!!!
Mako
Old 07-12-02, 03:51 PM
GregH's Avatar
Super Moderator
Received 34 Votes on 32 Posts
R-22
mako:
The cylinder of R-22 is not near as valuable as what R-12 would be.
The cost savings in supplying your own refrigerant when a tradesman does work for you would not be worth it.
Refrigeration and A/C work are not generally a DIY trade.
Sell the stuff and buy yourself something more usefull.
Old 07-12-02, 11:00 PM
T
telco tech
Use or sale of R22 to an unlicenced person is illegal (EPA certification to posess or buy) I'm not sure if you would be grandfathered under the law. There is some kind of of ranson money to be paid for reporting violators, but I'm not sure if it is effective. Bottom line I'd keep it low profile....
Old 07-13-02, 04:53 AM
GregH's Avatar
Super Moderator
telco tech is correct
You should ensure that whoever you sell the refrigerant to is qualified to use it.
Old 07-15-02, 04:46 AM
mako's Avatar
My landlord (a steel contruction company owner) knows a number of residential A/C companies. I gave it to him so he can divy it out. He's a great guy and honestly I don't have the patience to try to sell it. Thanks for the help folks!!!
