where is the thermostat located on a Lincoln Mark VII
franpb24's Avatar
07-13-02, 02:22 PM   #1
franpb24
Joe_F's Avatar
07-13-02, 03:13 PM   #2
Joe_F
Follow the upper radiator hose to the block. It should be in there.
Check the autolibrary.org link below for more ideas.
toyotaman11769's Avatar
07-13-02, 05:42 PM   #3
There is a housing in the middle of the lower hose, it's in there.
Word of caution...in the upper medal tube connecting both heads under the plastic top cover is a plug. When you refill the system fill through that hole to fill the block. When full close up and finish off through coolant tank. If you don't do this way it will just overheat and boil over, cause the block is'nt full
BTW use a Ford stat
Larry
07-13-02, 05:46 PM   #4
Sorry misread, Thought it was a Mark VIII, My bad. Joe is right on for a 5.0
Larry
