throttle position sensor
Old 07-15-02, 06:12 PM
sdwalker
how do i adjust the throttle position sensor on a 1989 ford f150 4wheel drive 5ltr w/overdrive,automatic
Old 07-15-02, 06:40 PM
B
it should be reading 1 to 1.1 volt on the green wire with the throttle closed the holes on the tps sensor may be slotted to allow slight turning to adjust the tps if they are not slotted then you would have to adjust it with your base idle screw wich shouldnt need adjusted unless someone has already moved it.
