Eletrical problem
TRH's Avatar
07-16-02, 03:10 PM   #1
TRH
Eletrical problem
I have an electrical problem with a 84 Nissan Maxima, 6 Cyl, Auto Trans, 110,000 miles.
The electrical system is dead except for the power windows/ sunroof. The symptoms I am encountering are as follows:
1. Car does not start ( no power to the starter yet I hear an electrical sensor )
2. No lights
3. Windshield wipers don't work
4. No Horn
5. No Emergancy Flashers
I checked the fuses in the fuse box under that dash (all ok)
I checked the grounding connections and battery terminals (all ok)
I checked the fusible links, Battery and on the fender (all seemed ok)
I inspected the steering column wiring/connectors (all ok)
Charged/ verified the battery is ok as well as the connections.
Where should I look next?
The car is not worth too much but someone wants to give me something for it as long as it runs. Any help would be greatly appreciated.
Joe_F's Avatar
07-16-02, 10:13 PM   #2
Joe_F
Check your work again, you missed something. Is the battery fully charged?
Tug on the fusible links really well, likely one is burned.
TRH's Avatar
07-21-02, 10:49 AM   #3
TRH
Eletrical problem
I double and tripple checked the fusable links. Charged the battery and changed it, yet the same symptoms are accuring.
Joe_F's Avatar
07-22-02, 06:03 AM   #4
Joe_F
Get a wiring diagram for it (try Autolibrary.org below) and follow the main power and ground leads. Something is compromised somewhere.
