is there any use trying to put this tensioner back on?
bmount1217's Avatar
07-18-02, 08:58 AM   #1
bmount1217
the truck has 62,000 miles, I put a new belt on it a week ago, but it squeaks really loud, so I figured I neede to tighten it. Well the whole tensioner came out, I did notice iron filings as i was bolting it. What does the tensioner replacememtn consist of?
Joe_F's Avatar
07-18-02, 09:00 AM   #2
Joe_F
PLEASE use your reply button to reply to posts rather than creating new ones.
Again, the tensioner should not come apart in pieces like that as I recall. Any GM dealer should be able to get you a new one in short order. As I recall it's the tensioner and the pulley assembly. Their parts microfilm will show the picture and the part number and what comes with what. I suggest you hit a GM parts counter for it.
bmount1217's Avatar
07-18-02, 09:02 AM   #3
bmount1217
this is gonna be so expensive
Dealers parts are so expensive....what about a junkyard?
Joe_F's Avatar
07-18-02, 09:04 AM   #4
Joe_F
You're likely to get worn out junk like you have and be back to square one. Worth the money on a GM part. I do not think they are that expensive.
Have you called various dealers to find out? Get the GM # from the dealership and then you can order it wholesale from www.gmpartsdirect.com
bmount1217's Avatar
07-18-02, 09:10 AM   #5
bmount1217
byt he wya...I have the 4 cyl 2.2 l
The tensioner seems to be mouted to the side of the motor on a panel.
Joe_F's Avatar
07-18-02, 09:11 AM   #6
Joe_F
Again, check the autolibrary link I list in my signature file (what follows every post I make) and the instructions are likely contained there .
