Brakes
Vendetta's Avatar
07-19-02, 03:22 PM   #1
Vendetta
Brakes
I have a 96 Nissan Sentra. Whenever I am driving straight, the right outer break pad grinds against the disk. Whenever I turn right, the grinding stops. Whenever I turn left, the grinding is worse. What could cause this problem?
Joe_F's Avatar
07-19-02, 04:14 PM   #2
Joe_F
Have you checked to see that the pads are not worn out?
Vendetta's Avatar
07-19-02, 04:17 PM   #3
Vendetta
The pads are only a couple weeks old.
Joe_F's Avatar
07-19-02, 04:19 PM   #4
Joe_F
What quality were the pads? Were the rotors turned or replaced?
Was the hardware installed properly? If you had someone do it, back to them for a test ride and have them correct the problem.
Vendetta's Avatar
07-19-02, 04:24 PM   #5
Vendetta
I did them myself. But after I finished, everything was fine. Then they grind when I drive now, after a few weeks.
Joe_F's Avatar
07-19-02, 07:26 PM   #6
Joe_F
Still didn't answer the questions about the rotors.....but Ok....anyhow.
Go to the autolibrary link I have below and retrace your steps/work and see if that helps.
Vendetta's Avatar
07-19-02, 07:42 PM   #7
Vendetta
Thanks. I just took them apart and redid them. Yes, the rotors were turned recently. It works now. Thanks.
