buick cuts off when hot
Old 07-21-02, 08:26 AM
chewychops
Unhappy buick cuts off when hot
I have a 1990 buick centry with 3.1 liter . Car runs fine until
it gets hot then it cuts off and will not start until it cools down
and then it will start and run fine until it gets hot and its the
same thing ? please help
thank you
Old 07-21-02, 09:48 AM
Joe_F
Does it have spark at the plugs when this happens? Hold a plug wire to ground and look for a fat, blue consistent spark when you have this trouble.
If there's no spark, suspect the ignition system (coil, module, crank sensor, etc).
Check the autolibrary.org link I have below for more ideas.
Old 07-22-02, 05:32 PM
chewychops
crank sensor
thanks for help so far .i put ice on the crank sensor when it
hot then it started up this work good .now i hope you can
help me and tell me how to take out the old one and put in
the new one are there special tools i need
thanks a lot
Old 07-22-02, 10:36 PM
there is no special tools needed just take out the one bolt and slide it out of the block and then install your new one when the engine is cool it is usualy easier to change due to its location.
every once in a while the sensor will get stuck in the block and may break off when trying to remove just hope that isn't the case with this one.
