fabricating angle rings for gauges in truck ???
Old 07-23-02, 12:26 PM
JeeperJake
okay, i ordered angle rings for my 2 1/16" autometer gauges, but i need one for my 3 3/8" speedometer. autometer doesnt make one, so i was wondering if anyone had an idea. does pvc come in 3 3/8" ??? remember, this is the inside diameter of the hole, not of the entire pipe. thanks
- jake
Old 07-23-02, 12:36 PM
Joe_F
Try McMaster Carr, Grainger, or an industrial supply shop. I'm sure there are gauges in different industries that are this diameter.
Old 07-23-02, 02:00 PM
JeeperJake
looked around a little bit, and i cant even find pipe in a 3 3/8" size. whats the deal? am i gonna have to make my own? what about pvc or copper pipe or tubing or something?
Old 07-23-02, 02:41 PM
Joe_F
Have you checked the industrial supply companies I've mentioned? If there's a gauge that size, there's likely a bezel that size. Perhaps 3.5" not 3 3/8.
Check all the various gauge companies such as VDO, Autometer, Sun, Stewart Warner, etc. If it's not a standard industry size, you're probably going to have someone make it up for you..
Old 07-24-02, 12:22 AM
knuckles
It should be no problem for a machine shop to turn out a 3 3/8" id piece of aluminum. Supply them with your smaller bezels & they can cut the angle to match. Shouldn't be terribly expensive & will look much better than PVC.
