91 lumina no spark new coils crank sensor icm plugs wires
Old 07-24-02, 10:27 PM
sirslinkster
friends have a 91`lumina with no spark they replaced the ignition control module and coils still no spark. so idid the wires plugs and then the crank sensor it only hase one stillnospark and no engin codes
Old 07-24-02, 11:18 PM
i would suggest you get a wiring diagram and check for power and ground at ignition module.
Old 07-24-02, 11:24 PM
knuckles
I agree w/ bejay. You might also want to check the 10A fuse in the underhood fuse box.
Old 07-26-02, 01:07 AM
sirslinkster
bejay thanx im going to go over it with a multieter this weeknd
Old 07-26-02, 01:09 AM
sirslinkster
knuckels thanx for yor sugestion but the fuses are all good
Old 07-28-02, 10:19 PM
sirslinkster
thanx guys had no power at the icm so i double checked the fuses somebody put it back in a dead hole it runs now but awfull rough the book says something about a tech1 scanning tool to do the idle learn or somrthing like that could that be causing detonation and bad idle also you cant hold the pedal in one spot you have to keep adjusting or it droops any advise greatly apreceated thanx again bjay & knuckles
Old 07-29-02, 12:16 PM
Joe_F
Have a look at autolibrary that I have bookmarked below.
