Rolling joint compound on walls
Old 10-09-02, 07:19 AM
cheesensweets
I have some walls that need a few skim coats of joint compound. Apparently the previous owners removed wallpaper from the walls and didn't bother to properly remove the glue and proceeded to paint over the glue. Or this is what I'm guessing happened. I need an easy way to get some skim coats of drywall on the walls and was thinking of thinning the compound and rolling a few skim coats on letting them dry in between. Can this be done and if so what type of roller should I use?
Old 10-09-02, 08:06 AM
I have only seen it done it books.
They use the roller to apply the mudd (thinned) and then come back with a huge 18" taping knife to smooth it out.
I have thought about it myself, but have not had the courage to try.
The book I saw was at Lowes. It was near the paint dept.
