08-16-03, 07:07 AM
Morris Branch
plastering over greenboard
I need to add greenboard to my bathroom walls where I removed the tile. There is plaster on wallboard already above the area where I will put the greenboard and I would like to mate it and then apply venitian plaster to the whole wall. can I plaster over the greenboard with out problems? Any specail material or techniques needed?
Thanks! Morris Branch
KS
08-16-03, 11:41 AM
The reason I asked what brand is there may be a bonding issue. If you are using venetian plaster finish from home depot or a paint store then don't worry, it will stick no problem. Also since its in a bathroom you will want to put the sealer over it. Is this your first time using Venetian Plaster? I do it all the time and can give you some tips.
