Corner sealant
Old 10-16-03, 12:23 PM
mg33
Corner sealant
I have vertical corner cracks from floor to ceiling of both side of a wall that's perpendicular to exterior wall. Mud had been applied but the cracks reappeared. Can you apply paintable sealant in the corners so that it is flexible to accommodate movement? Or applying fiberglass mesh is the better route?
Old 10-16-03, 12:48 PM
coops28's Avatar
If its directly in the corner just caulk it. Don't ever put mesh in a corner. It's only for flats.
Old 10-16-03, 01:00 PM
mg33
thanks for your response.
when spraying texture, will it stick to sealant? will sealant be noticeable once painted? is there a sealant you would recommend?
thanks
Old 10-16-03, 05:22 PM
Sillconized, acrylic, latex caulk will adhere well, is flexible, and takes paints and finishes readily. I believe it will do the job for you.
Trackbacks are On
Pingbacks are On
Refbacks are On
