damaged plaster ceiling
Old 06-13-00, 06:23 PM
Guest
Post
My plaster ceiling has 200 staple holes and a 1/4" crack the length of the room. The room is 12x 13. I believe there is old wallpaper that has been painted over. Can I texture over the wallpaper, or do I need to cover w/ drywall first?
Old 06-13-00, 09:13 PM
Guest
Post
From what you have posted, I would guess that this 1/4" crack has been on ongoing problem. What's causing it? My guess is that the ceiling joists are over spanned. I would suggest correcting the cause of the crack first, and patch it later. If you cover it with another layer of sheetrock, that will probably just crack also.
quote:<HR>Originally posted by j'ouvert:
My plaster ceiling has 200 staple holes and a 1/4" crack the length of the room. The room is 12x 13. I believe there is old wallpaper that has been painted over. Can I texture over the wallpaper, or do I need to cover w/ drywall first?<HR>
