Patching exterior rotted wood
Old 05-22-00, 08:06 AM
Post
I have exterior wood columns that have water damage around the base (looks like water seeped in around caulk). I have dug out the old rotter wood. What is the best way to repair. I am a novice so is this something that is straightforward or should i call a pro?
Old 06-19-00, 06:29 PM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by AndyG:
I have exterior wood columns that have water damage around the base<HR></BLOCKQUOTE>
If you know the damage is not structural, you might try using a compound called Mr. Mac. It comes as a powder you mix with an included liquid. They have kits to repair wood, metal and concrete. The wood repair stuff dries very, very hard, but I think it doesn't take a stain, it has to be painted.
Old 06-24-00, 12:27 PM
Post
After cleaning out the decayed wood, assuming that you have a reasonable amount of sound wood left, try using some wood hardener by Minwax. This is a very thin liquid that soaks in readily and solidifies the wood fibers- kind of like paper mache'. I have found this to be good insurance before caulking or puttying. Good luck!
