Plaster and asbestos
Old 07-29-00, 11:39 AM
Exclamation
Hi
I am a little worried about the possible use of asbestos in plaster, namely that of lath
type and possibly later stuff too (I don't know age of building or any ages at which any modications may have occured). Since I know nothing about plaster, could you
please shed some light on this issue before commencing more work on another house. I appreciate that it is hard to determine content without analysis - but
am no longer at the property so cannot take a sample and not being a professional in this field, I have little idea.
Best regards - your help is most appreciated
Brett
Old 08-14-00, 03:04 PM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by brettdonovan:
Hi
Brett
<HR></BLOCKQUOTE>
Brett,
"Normally", there should be no asbestos in plaster. I have never heard of any instances of plaster containing asbestos. Having said that, it is very common to find asbestos insulation on piping in houses old enough to have plaster walls. The asbestos insulation is normally on the hotwater/steam heating pipes, and most often contained in the basement.
Rick
Old 08-14-00, 09:48 PM
Post
Rick is correct, but only if modern plasters are considered. Formerly asbestos was used in cheap plaster jobs as a substitute for wool. It was also used in swimming pool plaster, was contained in older drywall joint compounds, and a host of other products. A list of suspected building products (by the EPA) exists here http://www.epa.gov/earth1r6/6pd/pd-t/asbmatl.htm
Asbestos is a concern only if it's disturbed or ingested. If you want to know more, roam the EPA site http://www.epa.gov/opptintr/asbestos/index.htm
Old 02-09-05, 12:41 PM
remodel1938
asbestos in plaster
Yes, plaster in homes and buildings built before the 70's may contain asbestos. You must have it tested to be sure. People who say that they have not heard of asbestos being in plaster are uninformed on the subject. I have had plaster samples from homes and many jobsites test positive for asbestos.
