Ceiling wallboard patching
's Avatar
08-27-00, 08:40 AM   #1
All:
I just added recessed lighting to my Kitchen. In the process of installation I found that there were pipes, supports etc. that I had not planned on.
The bottom line is that I had 4, 5" square holes that were not needed. I tried to patch by cutting a piece of new wallboard the same size of the hole in the ceiling and proceeded to tape and patch. Now that I have finished, the patches are very noticeable.
What can I do? I was thinking about textured paint. There was one other small problem I have and that is I tried to tape and patch piece of wall board that had a crater from small water damage and wound up with the same problem.
Please give your comments.
Gene
's Avatar
08-27-00, 12:09 PM   #2
Drywall mud shrinks as it dries and this may have caused part of your problem. I always use 3 coats allowing time for each coat to dry. Be sure to prime your patches before painting.
's Avatar
09-02-00, 04:28 AM   #3
Also, a patch on a slick ceiling(or anything else) must be feathered out. I would say on a 5 inch problem, assuming the patch doesn't hang below the rest of your ceiling, you would need to feather the patching at least a foot all the way around. This is best done with a 10 inch drywall blade but can be done with a 5 or 6 in steps...Mike
