Using primer with texture
Old 02-09-04, 06:58 AM
DBRaider
I was told you could use primer instead of water with your texture to reduce the number of steps ot primer/texture...is this true? I am going ot use a hopper ot spray a knockdown finish. Should I primer first or can I mix primer with the texture and do it all at once?
Old 02-09-04, 03:43 PM
coops28's Avatar
You can mix paint with the texture but its a huge waste. For best results, prime before and after. If you know what your doing you can skip the before part.
Old 02-10-04, 01:12 PM
awesomedell's Avatar
DBRaider,
Hello & welcome to the forums. I always primer before shooting texture, and again afterwards. I do think that adding primer to the texture mix helps brighten the ceiling. Now a pro painter will totally disagree with me about mixing primer into anything, but I'm going on experience and lack of call-backs for redos.
Trackbacks are On
Pingbacks are On
Refbacks are On
