Humped / Wavy Plaster Walls
Old 03-01-04, 08:21 AM
P
My older (1953) bungalow has original plaster walls.
The plaster seems to be applied to 2' x 4' backer panels that are attached to the studs. The finish on the exterior walls is quite uneven with the edges of the backer panels being noticably visible. If you run your hand down the wall you feel the wall "hump" out between the joints.
FWIW, I suspect that this is result of the joints drying faster than the middle and shrinking more - but its just my guess. To me it would seem to explain why the interior walls don't have the same problem.
My initial plan was to find a good plasterer and have him skim the walls to eliminate this. Then I started wondering if this is the sort of thing that I could successfully do myself.
I'm comfortable with drywall and joint compound, but have not had any dealings with plaster. Are they similar to work with or is there anything particular I need to know about working with plaster?
So far, I think the most important thing for me as a non-professional at this is to find the widest knife I can.
Old 03-01-04, 08:27 AM
prowallguy's Avatar
Received 2 Upvotes on 2 Posts
I work with joint compound a lot, but I'm not comfortable with working with plaster to skim coat. I think its a whole different beast to skim coat with plaster compared to mud. But I'm only a paperhanger. The Drywall guys can assist you better than me.
Old 03-01-04, 04:03 PM
awesomedell's Avatar
Plaster is definitely alot harder to do than drywall mud. If you're pretty comfortable with working in drywall mud, I'd skim the wall with it.
