Texture, Knockdown
Old 03-03-04, 10:08 AM
justmejulie
Texture, Knockdown
Can I texture over a wall that has a fairly new single layer of wallpaper? I removed around the edges. It is very secure with only drywall underneath. Not looking forward to removing the wall paper. I have read all the tips and know how to do it. It is just very time consuming....
Old 03-03-04, 10:09 AM
coops28's Avatar
Best thing to do is remove wallpaper. If you just aren't going to do it then prime the wall first.
Old 03-03-04, 10:19 AM
justmejulie
Thanks, that I am going to remove it. Guess I was hoping for a miracle. I was going to primer after I textured, but, should I primer before I texture? (or both?) With water or oil base?
Old 03-03-04, 12:22 PM
coops28's Avatar
For best results with knock down prime before with latex primer. No oil. You will also need to prime after.
