Screw anchors and old, brittle plaster walls
bonbuttercup's Avatar
04-26-04, 04:43 PM   #1
bonbuttercup
Is there a particular anchor (plastic or metal) that works best (or better) than others for plaster walls?
Currently I can hardly get a nail in the wall as apparently there's a thin of layer metal meshing in the plaster.
awesomedell's Avatar
MO
04-28-04, 06:06 AM   #2
I'd suggest using a toggle anchor for your wall. These are also sometimes referred to as butterfly bolts. Use a drill if needed to make the holes to insert the toggle anchor in.
