Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
filling big gaps? -- great stuff plus mud?
Old 06-11-04, 10:25 PM
dsw
dsw is offline
i've just replaced some windows and on one of them (the side unit of a bay window) i've got a big gap between the moulding and the existing wall -- because it's a bay window, the moulding actually cuts at about a 45 degree angle from the existing wall.
does anyone have suggestions about how to fill the rather deep and wide (about 1 inch) gap that exists? a carpenter friend suggested spraying in great stuff (??) foam insulator and then spreading mud over it....
Old 06-13-04, 06:47 AM
coops28's Avatar
You can cut the drywall back to a stud and patch in with drywall. You might be able do the foam stuff. If you try it, after it is set up dig out a 1/2 inch groove and fill that with quick set mud. I wouldn't go directly over the foam.
Old 06-30-04, 07:57 AM
Jean Luc
Can an additional piece of molding be used to close the unsightly gap?
