thickness??? sheetrock
thuthu's Avatar
OK
08-12-04, 07:45 PM   #1
My house was born in 56 I am replacing some of the sheetrock in one of the bathrooms it says 1/2" on it but the sheetrock i'm putting on looks almost an 1/8 thinner it to is 1/2" did they start making the stuff thinner now as opposed to when real men made the stuff long ago?
awesomedell's Avatar
MO
08-13-04, 04:30 PM   #2
I might be wrong about this, but I believe that sheetrock used to not have the recessed edges on it, that would account for the 1/8" difference in the thickness. If that's the case, it would make it a bit easier to tape & finish if you were to cut the recessed edge off of the new sheets where they are butting to the old existing stuff. Good luck!
StephenS's Avatar
08-14-04, 08:23 PM   #3
possilby the original sheetrock is 1/8" thicker
or
The entire area was skimmed over with 1/8" top coat of compound
or
the section you are mating to is near a seam having a 1/8" build up of a top coat compound
solutions:
mend the seam and float the seam onto the new piece of sheetrock far enough to disguise the difference
or
shim the wall with 1/8" strips of wood
or
use 5/8" sheetrock...
thuthu's Avatar
OK
08-15-04, 06:09 PM   #4
StephenS
thanks im going to float it in thinking about it im glad it's giving me room to float I should be through with this project keep puttin it on the back burner
