Hanging a mirror on drywall....
I have a mirror that weighs appx. 18 pounds. The spot I need to hang it on does not line up with the studs. Is it okay to hang something that weighs 18 pounds using drywall anchors and screws?
Thanks a bunch!
Thanks a bunch!
Received 0 Votes
screws and anchors are rated according to weight. If you need to sopport a mirror with 2 anchors each one should be rated for 10 lbs or 1 anchor rated at least 20 lbs. I like the ones that are screwed into the drywall rather than the push in ones. They hold a tremendous weight, but regular plastic anchors or molly bolts with the proper rating will do.
Received 0 Votes
how can an anchor be rated for 100lbs? Doesn't it depend on the drywall as well? For example, if you screw in one of these anchors isn't it susceptible to pulling out of the drywall due to the drywall around the anchor being disturbed by putting in the anchor?
still learning...
still learning...
Received 0 Votes
http://www.ooks.com/cart/viewitem.cf...erID=-25027976
the-dude
the hanger is installed using 3 short steel pins driven in at a downward angle...The wieght of 100lbs is distributed to a larger area of the drywall...the success of the hanger certainly relies with proper installation of the drywall...though it is not susceptible to pullout as a single screw with wire attached will be...
the-dude
