Question regarding Kitchen wall
Old 10-12-04, 10:26 PM
P
I am currently remodeling the kitchen and removed the laminate Backsplash that went up from the counter about 18". When i removed the backsplash, much of the plaster behind it was damaged. I want to chisel it out and put up something in its place and then tile over it. Should i bother keeping the wood lathe or take it all out to the studs? Secondly, I need something that is waterproof, pretty thin (i'm not sure what depth yet depending on removing the wood lathe or not), able to tile over easily, and i can easily cut out fixture cutouts for the new outlets i am putting in.
My other question is: do i have to fix the walls that had the old cabinets on them if i am putting new cabinets where they went? The only problem with them are the numerous nail holes that had kept the old cabinets up.
Thanks in advance
Old 10-16-04, 01:25 PM
coops28's Avatar
You can leave lath or remove, your call. I would remove it if you want to update electrical, etc... Usually you put up regular drywall behind tile backsplash. If your new cabinets have a back on them then go ahead and leave the wall the way it is. Just fix what shows.
Old 10-16-04, 10:04 PM
P
thanks
I thought it was important to use waterproof backing underneath the tile backsplash just in case when its close to a water source, so i was going to use cement board but it doesn't matter?
Old 10-17-04, 12:37 PM
T
Received 2 Upvotes on 2 Posts
Backsplash
Drywall is fine for backsplash area because it is not exposed to water like tiles are in showers. Concrete underlayment is recommended in tub/shower area. Backsplash tile is installed with adhesive (mastic). Use unsanded grout.
