Removing Wall Plugs/Anchors
Jermyn's Avatar
11-08-04, 08:28 AM   #1
Jermyn
I have to remove 16 wall anchors that the previous owner had used to put screws into to mount 8 mirrors.
What I don't know is how to properly remove these plugs so that I can patch the holes and paint.
The plugs are plastic.
Suggestions anyone????
majakdragon's Avatar
11-08-04, 08:35 AM   #2
If you can get to them, cut the larger outsice edge of the anchor off with a utility knife (sharp blade) and push then through. Could also drill through them since you are patching anyways. Good luck.
Jermyn's Avatar
11-08-04, 08:52 AM   #3
Jermyn
Thanks for the advice . . .
11-08-04, 08:57 AM   #4
Jermyn, Please post your question in only one forum. This one is more Patching and plastering so try to decide which topic you think best fits the question. Thanks.
joneq's Avatar
11-08-04, 09:00 AM   #5
I usually just use a phillips head screwdriver and push them in 1/4 " this leaves someting to stop the filler from going through and indents the area all in 1 shot. I also use lightweight patch [like thick whipped cream] it dries fast don't shrink. Leave it a little proud of the hole and sand in an hour or so then paint
rustyautumn's Avatar
03-06-10, 11:42 AM   #6
Another way to remove difficult plastic wall anchors
I'm redoing a bathroom and there are a lot of wall anchors. Screwing in a screw part way and pulling the screw and anchor out worked on most of them. However, there were a couple that just wouldn't budge where the curtain rods and blinds had been installed. They had to come out as they aren't where the new hardware will be installed.
I had a couple of large eye hooks (for hanging plants outside). They were larger than the screws that had been in there. I twisted them in and put a screwdriver through the eye and worked out all the remaining anchors. I'm going to have patching to do, but that was a given.
marksr's Avatar
TN
03-06-10, 04:31 PM   #7
Welcome to the forums rustyautumn!
Providing it won't interfere with mounting the new hardware, I normally knock them in and patch over them - it's a whole lot easier and quicker
retired painter/contractor avid DIYer
