poor quality wall under wallpaper
Old 03-11-05, 03:06 PM
joedeloca
can anyone tell me how to make this wall smooth or texture it myself?
Old 03-11-05, 08:06 PM
awesomedell's Avatar
Hi Joe and welcome to the forums!
You're going to have to give us a bit more to go on. What's the "poor quality wall under the wallpaper" comprised of? Standard sheetrock, traditional plaster over lath, or veneer plaster over blue board? How old is the house, has it ever been remodeled? The more info we have the better advice you get in return. I've sprayed gardz over wallpaper on old plaster walls where the wallpaper was bonded well to the wall & then shot med splatter texture on that and then put another coat of Tuff-Hide Primer over that and the walls looked like brand new. Post back with a bit more info and let's see what we're lookin at.
Old 03-13-05, 05:13 AM
need more info-plaster? cracks?paint?
what are you going to do on the wall after?
Old 03-21-05, 07:08 AM
TinaSC
We too have bad walls to work with
Some of our walls have holes in the plaster about 1 inch across and 1/2 inch deep. Cracks are about as wide as you can geta toothpick in. I am not sure what is under the plaster though. Can anyone tell us what to do to get these ready to paint? Thanks!
Tina in SC
Old 03-21-05, 05:12 PM
Tina in SC
For the most part you can patch everything with spackling. On the cracks take a screwdriver or edge of a putty knife and score the cracks then patch and sand as needed. The holes may be a little harder, if there is lath or plaster behind the hole you should be able to just patch it but if it is a open hole you will need to either plug it or tape over it [drywall tape set on wet mud, dry then recoat]
