06-13-05, 01:46 PM
John Langton
How much damage?
Taking off the dado (?? spelling) rail from around the house which was put up in an abismal was and have damaged a bit of the wall. A link to the pic is here could anyone take a look and advise me on how seriuos this is and is it repairable myself or should I get a specialist in. There are a few more areas like this around the house but this is the worst
Thanks for any help
John
http://i8.photobucket.com/albums/a47...n/IMGP0620.jpg
PS please ignore the decoration it is discracefull!
Thanks for any help
John
TN
06-14-05, 04:02 AM
John Langton
http://www.trp.dundee.ac.uk/research/glossary/dado.html
http://www.mcganns.com/dados.htm
Here you can see the dado rail around the centre of the wall
http://www.irishpropertymoves.ie/kil...12/KILD12D.jpg
Maybe I didnt make it clear but the damage to the wall occurred when removing the dado rail as it was nialed and also glued to the plaster for some strange reason. I do not want to replace the dado rail I know want the area to be flat ready for painting to match the rest of the wall
John
John
TN
06-14-05, 08:53 AM
The new pic helped. The dado is a chairrail. To repair the walls you will need to insert new sheetrock in any places too big to mud and tape. For the most part you will be able to mud and tape, let dry remud and sand until finished. Some carpenters glue/caulk their trim to the wall so as not to use as many nails. Repairing the walls isn't all that hard of a job but will be time consuming. Use of durabond [fast setting mud] can speed things up.
06-14-05, 10:41 AM
John Langton
Thanks for your time and info mark. Im am here in the UK think we call it dado rail here but at least we are both talking about the same thing now
As for this sheetrock is it called the same over here in the UK? I have never done anything like this before and im wondering if it might just be easier to call someone out. Also how do you replace the paper that is above the plaster?
John
John
TN
06-14-05, 01:39 PM
In the US it is called sheetrock or drywall and occasionally wallboard. It is usually easier to let someonelse do the work but always cheaper to do it yourself. Sheetrock is made of ground gypsum sandwhiched between to layers of paper. The paper tape that is mudded onto the wall will be sufficent to replace the paper that has peeled off the rock. Because of the multiple trips involved in this repair you can expect a professional to charge accordingly. Wish you luck with your repairs.
06-14-05, 02:32 PM
John Langton
Thanks mark your posts help me too understand it I think Ill have a crack myself. If I cant do it I will get someone in to finish off my bad work :-)
John
John
